2015年7月3日 (五) 19:43Admin讨论 | 贡献的版本
Arduino官方库
The Arduino environment can be extended through the use of libraries, just like most programming platforms. Libraries provide extra functionality for use in sketches, e.g. working with hardware or manipulating data. A number of libraries come installed with the IDE, but you can also download or create your own. See these instructions for details on installing libraries. There's also a tutorial on writing your own libraries.
标准库
- EEPROM - 读写“永久”储存
- SD - 用于读写SD卡
- Servo - 用于控制伺服电机(舵机)
- Stepper - 用户控制步进电机
- TFT - 用于在TFT屏幕上绘制文本、图像及形状
- WiFi - 用于使用WiFi扩展板连接到网络
The Matrix and Sprite libraries are no longer part of the core distribution.
Due Only Libraries
