EEPROM:put()
put()
描述 向EEPROM中写入任何类型数据或对象。
EEPROM.put(address, data)
address: 写入的位置,从0开始 (int 整型) data: 写入的数据,可以是一个基本类型(例如:float 浮点型)或者是一个自定义的结构体。
数据传递的引用
这个函数使用EEPROM.update()来执行写数据,所以如果值没有改变不会重复写入的。 示例
#include <EEPROM.h>
struct MyObject{
float field1;
byte field2;
char name[10];
void setup(){
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
float f = 123.456f; //Variable to store in EEPROM.
int eeAddress = 0; //Location we want the data to be put.
//One simple call, with the address first and the object second.
EEPROM.put( eeAddress, f );
Serial.println("Written float data type!");
/// put() is designed for use with custom structures too.
//Data to store.
MyObject customVar = {
3.14f,
65,
"Working!"
eeAddress += sizeof(float); //Move address to the next byte after float 'f'.
EEPROM.put( eeAddress, customVar );
Serial.println( "Written custom data type!")
Serial.println( "View the example sketch eeprom_get to see how you can retrieve the values!" );
void loop(){ /* Empty loop */ }
