RTC 1307
当零件通过备用电源工作时,计时工作将继续进行。
- 供电电压:DC5V
- 56字节,电池支持的通用RAM,具有无限写入
- 自动断电检测和开关电路
- 工作温度:0℃~70℃
- 模块尺寸:45*19.5*6.5MM (长*宽*高)
- 孔间距:14.5MM
- 模块重量:5.2g
| RTCDS1307时钟模块 | Arduino UNO |
| VCC | +5V |
| GND | GND |
| SDA | SDA/A4 |
| SCL | SCL/A5 |
Arduino 库 : RTC DS1307 DS3231库 RTCDS1307库下载
/* arduino sketch -- arduino print date and time with ds1307 RTC breakout SETUP: arduino (UNO R3) ds1307 A4/SDA → SDA A5/SCL → SCL GND → GND Read More about DS1307: http://www.yfrobot.com.cn/wiki/index.php?title=RTC_1307 BY YFROBOT */ #include <Wire.h> // must be incuded here so that Arduino library object file references work #include <RtcDS1307.h> RtcDS1307<TwoWire> Rtc(Wire); void setup () { Serial.begin(115200); Serial.print("compiled: "); Serial.print(__DATE__); // 编译文档的日期 Serial.println(__TIME__); // 编译文档的时间 //--------RTC SETUP ------------ // if you are using ESP-01 then uncomment the line below to reset the pins to // the available pins for SDA, SCL // Wire.begin(0, 2); // due to limited pins, use pin 0 and 2 for SDA, SCL Rtc.Begin(); RtcDateTime compiled = RtcDateTime(__DATE__, __TIME__); // 存储当前编译的时间及日期并打印 printDateTime(compiled); Serial.println(); if (!Rtc.IsDateTimeValid()) { if (Rtc.LastError() != 0) { // we have a communications error // see https://www.arduino.cc/en/Reference/WireEndTransmission for // what the number means Serial.print("RTC communications error = "); Serial.println(Rtc.LastError()); } else { // Common Causes: // 1) first time you ran and the device wasn't running yet // 2) the battery on the device is low or even missing Serial.println("RTC lost confidence in the DateTime!"); // following line sets the RTC to the date & time this sketch was compiled // it will also reset the valid flag internally unless the Rtc device is // having an issue Rtc.SetDateTime(compiled); } } if (!Rtc.GetIsRunning()) { Serial.println("RTC was not actively running, starting now"); Rtc.SetIsRunning(true); } RtcDateTime now = Rtc.GetDateTime(); // 获取当前DS1307时间及日期 if (now < compiled) { Serial.println("RTC is older than compile time! (Updating DateTime)"); Rtc.SetDateTime(compiled); } else if (now > compiled) { Serial.println("RTC is newer than compile time. (this is expected)"); // Rtc.SetDateTime(compiled); } else if (now == compiled) { Serial.println("RTC is the same as compile time! (not expected but all is fine)"); } } void loop () { if (!Rtc.IsDateTimeValid()) { if (Rtc.LastError() != 0) { // we have a communications error // see https://www.arduino.cc/en/Reference/WireEndTransmission for // what the number means Serial.print("RTC communications error = "); Serial.println(Rtc.LastError()); } else { // Common Causes: // 1) the battery on the device is low or even missing and the power line was disconnected Serial.println("RTC lost confidence in the DateTime!"); } } RtcDateTime now = Rtc.GetDateTime(); // 获取当前DS1307时间及日期 printDateTime(now); // 串口打印日期时间 Serial.println(); delay(10000); // ten seconds } #define countof(a) (sizeof(a) / sizeof(a[0])) // 串口打印日期时间 void printDateTime(const RtcDateTime& dt) { char datestring[20]; snprintf_P(datestring, countof(datestring), PSTR("%02u/%02u/%04u %02u:%02u:%02u"), dt.Month(), dt.Day(), dt.Year(), dt.Hour(), dt.Minute(), dt.Second() ); Serial.print(datestring); }
程序下载地址:ClockWithSerialPrint
- 串口监视结果
