Micro:Bit JoyStick
YFROBOT JoyStick for Micro:Bit
YFROBOT JoyStick 是一款面向创客教育而设计并适配Micro:Bit的可编无线遥控手柄。
小车安装视频:即将发布......
Introduction
Function
Parameters
- One-key start switch x1
- Power indicator x1
- Buzzer x1
- N20 metal gear motor x2
Dimensions and weight
