红外接收
其他详见参考资料。
- 供电电压:DC3v3-5V
- 载波频率:38 kHz
- 周期:26μs
- 接收距离:10m
- 模块重量:2.2g / Mini遥控器:12.6g
示例一:获取键值
* Version 0.1 July, 2009
* Copyright 2009 Ken Shirriff
* http://arcfn.com
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
Serial.print("irCode: ");
delay(200);
程序下载地址:IRrecvDemo
最终整理按键值表格:
| 遥控器字符 | 键值 | 遥控器字符 | 键值 |
| 红色/关闭键 | 0xFFA25D | MENU | 0xFFE21D |
| TEST | 0xFF22DD | + | 0xFF02FD |
| 返回键 | 0xFFC23D | 快退/左2三角 | 0xFFE01F |
| 播放/一个三角 | 0xFFA857 | 快进/右2三角 | 0xFF906F |
| 0 | 0xFF6897 | - | 0xFF9867 |
| C | 0xFFB04F | 1 | 0xFF30CF |
| 2 | 0xFF18E7 | 3 | 0xFF7A85 |
| 4 | 0xFF10EF | 5 | 0xFF38C7 |
| 6 | 0xFF5AA5 | 7 | 0xFF42BD |
| 8 | 0xFF4AB5 | 9 | 0xFF52AD |
示例二:红外遥控
int RECV_PIN = 11;
int LED_PIN = 13;
pinMode(LED_PIN,OUTPUT);
controlLED(&results);
//Control the LED
switch(results->value){
case 0xFFA25D:
digitalWrite(LED_PIN,LOW);
break;
case 0xFFE21D:
digitalWrite(LED_PIN,HIGH);
break;
程序下载地址:IRrecvControl
