Mouse and Keyboard libraries
2017年9月13日 (三) 15:22Allblue讨论 | 贡献的版本
These core libraries allow a 32u4 based boards or Due and Zero board to appear as a native Mouse and/or Keyboard to a connected computer.
A word of caution on using the Mouse and Keyboard libraries: if the Mouse or Keyboard library is constantly running, it will be difficult to program your board. Functions such as Mouse.move() and Keyboard.print() will move your cursor or send keystrokes to a connected computer and should only be called when you are ready to handle them. It is recommended to use a control system to turn this functionality on, like a physical switch or only responding to specific input you can control.
When using the Mouse or Keyboard library, it may be best to test your output first using Serial.print(). This way, you can be sure you know what values are being reported. Refer to the Mouse and Keyboard examples for some ways to handle this.
Mouse
The mouse functions enable a Leonardo, Micro, or Due to control cursor movement on a connected computer. When updating the cursor position, it is always relative to the cursor's previous location.
- Mouse.begin()
- Mouse.click()
- Mouse.end()
- Mouse.move()
- Mouse.press()
- Mouse.release()
- Mouse.isPressed()
Keyboard
The keyboard functions enable a Leonardo, Micro, or Due to send keystrokes to an attached computer.
Note: Not every possible ASCII character, particularly the non-printing ones, can be sent with the Keyboard library. The library supports the use of modifier keys. Modifier keys change the behavior of another key when pressed simultaneously. See here for additional information on supported keys and their use.
- Keyboard.begin()
- Keyboard.end()
- Keyboard.press()
- Keyboard.print()
- Keyboard.println()
- Keyboard.release()
- Keyboard.releaseAll()
- Keyboard.write()
Examples
- KeyboardAndMouseControl: Demonstrates the Mouse and Keyboard commands in one program.
- KeyboardMessage: Sends a text string when a button is pressed.
- KeyboardLogout: Logs out the current user with key commands
- KeyboardSerial: Reads a byte from the serial port, and sends back a keystroke.
- KeyboardReprogram: opens a new window in the Arduino IDE and reprograms the board with a simple blink program
- ButtonMouseControl: Control cursor movement with 5 pushbuttons.
- JoystickMouseControl: Controls a computer's cursor movement with a Joystick when a button is pressed.
返回Arduino语法参考列表
