GITHUB 工程地址:RTC by Makuna
支持设备
DS1307
DS3231
示例
- - DS1307_Memory: This demonstrates how to write and read data from the extended memory of the device. This memory is retained even after the device has lost power./演示如何读写数据从设备的扩展内存。即使设备掉电内存依然保存
- - DS1307_Simple: This demonstrates how to set and get the date and time from the device./演示了如何在设备上设置和获取日期和时间
- - DS3231_Alarms: This demonstrates how to set the alarms and check when the alarms are triggered. This includes using the squarewave output to trigger an interrupt./演示如何设置闹钟和检查何时触发闹钟。这包含使用方波输出触发一个中断
- - DS3231_Simple: This demonstrates how to set and get the date and time from the device./演示如何在设备上设置和获取日期和时间。
- - DS3231_StoreIt: This demonstrates how to turn off the Rtc clock so that the onboard battery will last longer./演示如何关闭RTC时钟以保证板载电池能持续更长时间
DS1307
SD类提供了访问SD卡和操作卡中文件和目录的函数。
- - begin()
- - exists()
- - mkdir()
- - open()
- - remove()
- - rmdir()
DS3231
File类允许读取或写入SD卡上单个文件
- - available()
- - close()
- - flush()
- - peek()
- - position()
- - print
- - println()
- - seek()
- - size()
- - read()
- - write()
- - isDirectory()
- - openNextFile()
- - rewindDirectory()
